If any of you have a 15khz compatible VGA monitor knocking about, its dead easy to connect Albert to it. I have the schematic here;
Might be of use to someone? It's how I connect my Einstein up to a Dell 2314H LCD monitor. I also show it working in one of my Youtube videos.
RGB to VGA lead for Einstein
- Attachments
- IMG_20190908_080605.jpg (706.07 KiB) Viewed 8548 times
Re: RGB to VGA lead for Einstein
It's been on my list for ages to get a 15khz lcd monitor! Still not got round to it
Nice work Mike, I'll give that a shot.
In fact it might help with the problems I'm having with my '256.
This first image shows the banding that I get when pulling video from the din socket. I suspect it's something to do with the fact there is no separated sync just a composite video signal. I think a sync separator would help if that is indeed the cause. I can't help wondering if there's something else though.
| There is a csync signal available on the VAMP connector, so I wired that up instead. And I got this:
| Weird huh? Why would it be b&w? This is (supposedly) an rgb signal! Could it be that the telly is in composite scart mode rather than rgb
*EDIT* Interestingly the tv reports scart/ntsc. Hmmmm. Curiouser.
