If that's todays MAMEUI 0.248 release then that is the final release, the maintainer of that project has now discontinued it. Also MESSUI at https://messui.1emulation.com/MikeDHalliday wrote: ↑Wed Sep 28, 2022 4:20 pm I have found mameui, which i assume is the same as messui?
But now you're upto date you'll have features added in the past 2-3 years such as the Einstein 256, and being able to directly load .COM files.
The XML is known as a Software List, it contains details of 'supposedly' good dumps of software. You'll generally find these matching disk images in MAME torrents. You should only be editing the XML files if you intend to submit new good software dumps to the MAME project.MikeDHalliday wrote: ↑Wed Sep 28, 2022 4:09 pm Also, all my Mess disk images do not work with MAME, even when they are in the correct folders. I also dont like how it has to refer to the XML file for the disk images. How do I load my own? Do i have to edit the XML file?
Loading software from the software list will always mount the floppy as write protected. I haven't used MAMEUI but there should be an option somewhere to load your own DSK files by letting you navigate and select an image, then MAME should prompt you for read-only, write back to image, etc.
