Language Uploads
Language Uploads
Tatung Einstein The Software Toolworks C V3.0
Attached is a disc image for The Software Toolworks C V3.0 and a generic manual for V3.1 (couldn't find V3.0!).
I have got as far as compiling the sample file HELLO.C but thats it so far. That works as follows:
C HELLO
various messages (wait 1 minute)....
AS HELLO
various messages (wait 1 minute 5 seconds)...
HELLO
says hello!
Hopefully there will be a faster compiler out there somewhere!
C80.zip
(83.66 KiB) Downloaded 1288 times
swtw-c80.zip
(175.01 KiB) Downloaded 1263 times
Re: Language Uploads
ED80
Attached is an image of ED80 - an 80 column text editor and an ED80 manual from Hisoft. Although I don't think the manual is specific to this version of ED80 the control command codes I tried worked OK.
Its difficult to write C programs without an editor!
Control key summary:
Code: Select all
Cursor Moving commands
^S           Character Left          ^D           Character Right
^H           Character Left (Alt)
^A           Word Left               ^F           Word Right
^O S         Tab Left                ^O D         Tab Right
^Q S         Start of line           ^Q D         End of line
^E           Line Up                 ^X           Line Down
^O E         Top of Screen           ^O X         Bottom of Screen
^R           Page Up                 ^C           Track-Info
^Q R         Start of File           ^Q C         End of File
Text deleting commands
^W           Delete Line
[DEL]        Delete last character   ^G           Delete this character
^O T         Delete word left        ^T           Delete word right
^Q [DEL]     Delete to start line    ^Q Y         Delete to end line
Block commands
^K B         Mark Start of block     ^K K         Mark End of block
^K V         Move Block              ^K C         Copy Block
^K Y         Delete Block            ^O P         Paste Deleted Block
^K R         Read Block from disc    ^K W         Write Block to disc
Quick cursor movement
^O G         Go to Line
^Q B         Go to start of block    ^Q K         Go to end of block
^K 0         Remember position       ^Q 0         Return to position
Find and Substitute
^Q F         Find First              ^L           Find Next
^O L         Substitute & Find       ^O A         Substitute All
Leaving ED80
^K Q         Quit and Exit           ^O Q         Exit without Backup
^K X         Exit with a Backup
Toggles
^V           Toggle change/insert    ^O I         Toggle auto indent
^O F         Toggle space display
Miscellaneous
^I           Deliver TAB character   ^O R         Restore line
^K F         Disc Directory          ^K J         Erase file from disc
^P           Control meta-key        ^J           Help key
ED80_(Hisoft)_Manual.zip
(1.2 MiB) Downloaded 1250 times
ED80.zip
(77.82 KiB) Downloaded 1240 times
SuperFORTH 1.12. Not tried it yet but it does boot up. The manual is here: http://www.tatungeinstein.co.uk/front/mans.htm
Forth112.zip
(33.51 KiB) Downloaded 1414 times
Borland TURBO Pascal V2.00A.
Boots up but not yet used in anger...
BorlandTurboPascal.zip
(74.33 KiB) Downloaded 1235 times
Turbo_Pascal_Version_2.0_Reference_1984.zip
(7.42 MiB) Downloaded 1228 times
Z80 FIG-FORTH 1.1.
I couldn't find a manual but there is a load of info on here: http://www.forth.org/fig-forth/contents.html
ForthFIG.zip
(62.88 KiB) Downloaded 1257 times
HiSoft Pascal.
My disc only has the compiler (use ED80 to create the source files I guess) and therefore no Einstein specific extensions for sprites etc.
I found a generic HiSoft manual for it, chances are the Einstein is under the 'Other Computers' section.
Edit - I have now got the manual for this, see below.
Further edit - it seems that the compiler is the only file included with this and has a number of built in commands for graphics!
Hisoft_Pascal_80_(Hisoft)_Manual.zip
(4.2 MiB) Downloaded 1265 times
HisoftPascal.zip
(27.71 KiB) Downloaded 1250 times
Not so much a manual for z80 Fig-Forth, but a few pages of a translation from Hungarian
http://www.massmind.org/techref/languag ... /index.htm
Have also found this interesting site
http://www.retroarchive.org/cpm/lang/lang.htm
Not sure how many of these will run on Albert, but they must be worth a try?
Hisoft Pascal Manual PDF.
Apologies for the poor scan - I only have a cheap flatbed scanner and didn't really want to destroy the manual pulling it apart.
HISOFT_PASCAL.zip
(5.12 MiB) Downloaded 1172 times
