DSK tool
DSK tool
Presenting dsktool.
BETA VERSION AVAILABLE
I'm working on an integrated utility that's a little easier to use than the previous tools I linked. You'll find the documentation, and the source and binaries, HERE
Feature requests, bug reports here please :D
Re: DSK tool
Excellent!
fatbob_gb
Re: DSK tool
Post by fatbob_gb »
This will make life much easier - Thanks
Re: DSK tool
I hope so! I opted for a command line program rather than a gui app because 1> cross platform gui is hard 2> can be driven by terminal scripts when developing.
Re: DSK tool
That's really cool!. Indeed, paired with a configurable editor like Notepad++ (or whatever programmer's editor you use) it's an invaluable tool for cross-developers.
Thanks!
Re: DSK tool
Well, here's my first report.
I've been trying to insert a compiled binary (as *.com file) into a DSK, without success. I'm using an empty sample DSK from EDIP and also a known working DSK with already some files into it. Of course the COM file is named following the 8.3 standard and it's not duplicated into the image.
The empty disk is not recognized and the tool shows "Invalid DSK..." error message, if I use the working DSK things change and there's no error; but if I try to DIR the contents, it's unchanged and only old files appears.
The tools seems to work to some extent, I can list the files of this last known working disk. I haven't tested yet the extract feature, only insert.
Maybe it only works with some DSK formats?, I've read the manual but it doesn't mention a word about it.
Re: DSK tool
Let me have the dsk images you're using and I'll try to repro. PM me for my email address unless you already have it.
Re: DSK tool
Also are you using Win, Mac or Linux version? Pre-compiled or self built?
Re: DSK tool
Sure, this is my test rigs:
- Windows 10 64bit, precompiled bin "dsktool.exe" that seems to work (at least it reports the usage and "dir" command works over a image).
- Windows 8.1 64bit, same dsktool.exe.
I'll send you my test dsk images; but my first try has been with the "XTAL205_40TSS.DSK" image inside the EDIP package (Error "Invalid DSK..."). After failing with that I've tried with the SPACETRAP.DSK, it only has STRAP.COM file and was correctly listed with dir command (Error: no error but no insert files at all).
I've also tested the following EDIP blank images: XTAL205_80TDS.DSK, XBAS_131_40TSS.DSK without luck, same "Invalid DSK file ...."
Many thanks!
Re: DSK tool
Attached files to test the tool:
dsktool_testfiles.zip
(13.43 KiB) Downloaded 954 times
The blank DSK and the COM that I'm trying to insert.
