I have just recently picked up a TC-01 with dual 3" drives. I'm looking for the best way to get software for it. Also, plug some knowledge gaps as pertains 3" disks & drives. The drives in the Tattie appear to be SS with a 34-way edge connector & molex power.
I also have:
- 1x 3" drive from a very poorly Amstrad 8256. The connector is a 26-way IDC and 'regular' power connector as you'd see on a 3.5" drive. Has Amstrad Pt No Z70312 marked on the PCB. Nothing else obvious.
- 2x 3" drives pulled from a BBC Micro. I think these are DSDD units. Connector is a 34-way edge connector. And I have a cable that'll connect them to the BBC. The drives are Sakyo Seiki Mfg Co Ltd FDU300-DA
- Greaseweasel rig.
- A couple dozen CF2 diskettes
Question: Will the DSDD write the 200K format? When I hook one disk up to the GW and try read the disk, the activity light come on but nothing spins. I've no idea if the drives are actually working, or that the bands are intact etc. Assuming the drives are working, should the GW work in this configuration?
Question: Can I drop in one of the DSDD units into the Tattie? Same question re: media? Can I use the CF2 media in the DSDD drive? Some of the media does say 'for single head drive' but they're flippy, so what gives?
Been a long time since I've had to deal with the 3" world, any help gratefully received?
Cheers!
e
