The above link works with my 5.25" floppy drive (TEAC FD55FV-30-U) and is able to read a few 700KB discs and show the file index. Some discs show no files at all, even though there is writing on the disc labelsarcadesy wrote: ↑Mon Jan 30, 2023 11:54 am https://www.tatung-forum.co.uk/viewtopic.php?f=3&t=83 << interesting thread about getting 800k from a Gotek dsk image
Drive 0 set to single sided 40 track
Drive 1 set to double sided 80 track
Drive 2 and 3 set to same as Drive 0 (I dont have anything connected so just configured as standard)
Not sure if my drive is busted or not, as there is a lot of squeaking and whirring going onwhen reading discs. It is very old and I cannot remember where I aquired it from.
When trying to run a program off the floppy, the heads just move back and forth and I get a Bad Data 1: or No Sector 1: error message.
What external 5.25" drives are other people using (Make and model with jumper settings)?
I have 6 boxes of 5.23" discs that I need to test and check, but that project has hit a brick wall
Maybe the drive (In it's current configuration) will work with Grease Weazle and allow me to image the discs and use them in Mame or on my Gotek?
Thanks
