MAME: Einstein Emulation
andy_rea
Re: MAME: Einstein Emulation
Post by andy_rea »
Interesting... is there an idiots guide to using the debugger ?
Regards Andy
Pernod
Post by Pernod »
andy_rea wrote: Thu Nov 07, 2019 7:05 am Interesting... is there an idiots guide to using the debugger ?
It's not an idiots guide, but the official documentation is at https://docs.mamedev.org/debugger/index.html
Hi Andy.
Set up mame in the usual way, with roms and all.
Start mame from the command line, mame einstein -debug
The debugger has a command line/box
> g
... will make it GO!
Hit return in the command line to make the emulation stop
> g [address]
... will go as far as address then stop
To run a tattie COM file without having to build a disk image:
start mame
> g
tattie boots, when prompt appears type 'g 100' on tattie
debugger will break at address 100H
> load comfilename,100
> g
That'll get you going, use the built-in help for the rest.
So, it works up to a point. There are still hangs but fewer now. One thing I have a hard time with is the memory view, which only seems to show the ROM even when RAM is paged in.
Start mame
$ ./mame64 -debug einstein
Start the emulation from the debugger, with a temp. breakpoint at $100
g 100
On the einstein use the MOS to jump to $100
>G 100
While stopped at the breakpoint go to the Debug menu and pop open a new memory window. The available views are Z80 :i001 program space, and IO space. program space is showing the content of the ROM despite the fact that RAM is now paged in. This is mame on a Mac. PC procedures may differ.
Is this something that can be fixed? I don't have a clue where to start in the mame source, it's a maze of twisty passages, all alike. Where could I start looking?
Have you tried typing xyzzy? :lol:
Pernod
Post by Pernod »
sirmorris wrote: Fri Nov 08, 2019 11:13 am While stopped at the breakpoint go to the Debug menu and pop open a new memory window. The available views are Z80 :i001 program space, and IO space. program space is showing the content of the ROM despite the fact that RAM is now paged in. This is mame on a Mac. PC procedures may differ.
This does seem odd and unexpected, on a PC I see RAM in the Z80 program space at this point.
In the memory window you can also select 'RAM/:ram/0/m_pointer' to always show RAM.
I think the mac build is a little bit special. Perhaps it's just how I build it. I'll check google for an official (or at least competent :roll:) mac build.
@vanpeebles :lol:
How do I go about downloading and installing the MAME emulator for the Tatung? Either Mac or PC - whichever is easiest.
I have never seen / used either. :shock:
And once up and running are there tools to drag in files to disc images etc.?
I have written a highly dubious and irritating text adventure in BBC Basic that I thought I would try to port to the tatty BBC Basic. :lol:
Pernod
Post by Pernod »
Lardo Boffin wrote: Sat Feb 15, 2020 7:52 am How do I go about downloading and installing the MAME emulator for the Tatung? Either Mac or PC - whichever is easiest.
Download from https://www.mamedev.org/
Documentation at https://docs.mamedev.org/usingmame/usingmame.html
Attached are the romsets required for Einstein emulation, just copy them to your mame/roms folder (do not unzip).
Lardo Boffin wrote: Sat Feb 15, 2020 7:55 am And once up and running are there tools to drag in files to disc images etc.?
Not sure how you would do that, maybe someone else has some ideas?
einstein.zip
(12.38 KiB) Downloaded 858 times
einst256.zip
(11.67 KiB) Downloaded 804 times
