einSDein troubleshooting
Not necessarily related to my keyboard but more likely the general instability of my tatty I am having troubles with the einsDein.
Sometimes when I switch on I get this:
Sometimes when I get a no discs in drive 2 or 3 error:
Sometimes it works and does DIR (keyboard permitting) and then fails:
I have cleaned the PIPE pins a couple of times.
So presumably it either doesn’t like the SD card or my flaky tatty?
Re: Keyboard troubles
I get this too, I reckon my Tatty is well flakey :(
It looks remarkably like the symptoms that Mr. vanpeebles has been seeing. It'll be interesting to see how his z80 transplant goes. I don't think this is an SD card issue. If you're worried that it's a defective board then I'll be happy to re-test it for you. I don't think it is though, as I had vanpeeble's board back for testing and it checked out fine :? Out of curiosity is your einsdein ROM an EEPROM (no window) type or a regular EPROM?
sirmorris wrote: Wed Jan 15, 2020 9:59 pm It looks remarkably like the symptoms that Mr. vanpeebles has been seeing. It'll be interesting to see how his z80 transplant goes. I don't think this is an SD card issue. If you're worried that it's a defective board then I'll be happy to re-test it for you. I don't think it is though, as I had vanpeeble's board back for testing and it checked out fine :? Out of curiosity is your einsdein ROM an EEPROM (no window) type or a regular EPROM?
What would be the best replacement z80 to buy? :)
I doubt it is the board as well.
Mine has an EPROM I believe (with a little bit of sticker covering the window).
When the keyboard works I can load some games (depending on the file name / keys working at the time) from floppy disc and they happily run.
Could it be a similar issue to Spectrums and the Z80 where stuff like the DIVMMC doesn’t work?
I get Z80s from here for Spectrums and ZX81s but not sure if they will work at 4MHz?
https://www.retroleum.co.uk/zx-spectrum-chips
Edit - I think Pokemon used to sell 8MHz Z80s on Sell My Retro.
Good place that, he sourced my Tatung replacement ram. I wonder if the new zilog made z80 would be best?
Tried sd setup in new tatung, worked perfect first time, then fell over ever since, doing the same no drive, which drive :(
No hex errors like first tc01, just endless no drive, which drive, indentical to lardo.
I'll keep updating this first post with any relevant information that comes to light regarding issues with einSDein.
When reporting an issue it would help if certain information was provided.
  • OS ROM version
  • einSDein ROM type (EPROM with window, EEPROM without)
  • SD card brand/size
  • A short precis of the symptoms experienced
