RAM Troubles
RAM Troubles
Currently had a ton of problems trying to get einSDein to run on my TC-01, after a ton of help (cheers SirMorris!) it's been narrowed down to hopefully a dodgy ram chip. I've got some turned pin sockets on the way and 8 memory chips on the way, fingers crossed! :lol:
robheaton
Site Admin
Re: RAM Troubles
Post by robheaton »
You best get that soldering iron heated up!
Re: RAM Troubles
RAM sockets fitted, after some epic desoldering! Phew! Have I got carried away with the braid and took out the solder from where the hole is?? (second picture)
Re: RAM Troubles
Don't worry about that. It's just where solder has flowed into the via from the wave soldering process. It's not electrically significant.
Congratulations on the job - looks very neat! Did you have any trouble with lifting tracks?
More to the point -
DOES IT WORK??!!!
* I'm guessing you're still awaiting RAM otherwise you'd have tried :lol:
Re: RAM Troubles
No I went real steady! I used rework jelly, using my solder sucker on the back first, then went round with braid top and bottom. Used all my braid too!
Ah so I don't need to fill that hole in? I was wondering between it has a line that goes from one to the next one.
The chips are in the post. I could continuity test all the pins to each other socket, apart from 2 or 3 pins if I remember right. I'm guessing they are not used.
Re: RAM Troubles
That's where I'm going wrong then - I usually use strawberry jelly. :roll: :lol:
Re: RAM Troubles
I wouldn't put this stuff on my toast :lol:
Re: RAM Troubles
Success anyway! 8 new chips and machine is working way better. I'm still getting the odd blue with purple specks interference. No doubt something else needs changing too!
Re: RAM Troubles
Mmm, caps?. I would consider a recapping although then Einstein, AFAIK, doesn't suffer usually of bad caps...or at least not like the Newbrain :mrgreen:
Re: RAM Troubles
To be honest I usually associate bad caps with 90s Japanese stuff and BBC PSUs. I've never capped a Sinclair that I've owned. Maybe a dodgy z80 or something? It's still struggling to play nice :(
